406 vs 400 sbc
Link
I am thinking of doing a 406 build and I was wondering if it would be better to just keep it a 400 for a budget drag build
melloelky
4,161
9,568
mass
lilbowtie's right, if you don't have to why bother.depending on what your plans are come into play also.
bracketchev1221
1,412
1,647
I would use whatever could get a clean hone with a torque plate and keep piston to wall acceptable.
88ss408
281
34
baie st anne n.b
A 406 is a .030 overbore. If your standard bore is good run with it. But if you have to bore and can get away with .010 or .020 do that.
81msw79
391
124
roselle park , nj
I agree with all the statements above. A factory 400 block is notorious for issues once you start punching them out. The walls are thin to begin with compared to other sbc cores. If you need to clean up walls keep it light like 88ss408 suggested. I got lucky with my short block it is standard bore and clean. I am just going to hone it and rebearing bottom end with some new pistons.
7,987
18,693
Totally agree. When I bought my car it had a 400 in it. It was pretty tired. I pulled the heads to take a look. It had already been bored 0.030" and had pronounced ridges at the top of the cylinders. The consensus was it needed to be sonically checked to see if it could take a 0.040" overbore. I sold it and moved on.
bracketchev1221
1,412
1,647
Just don't lock yourself into weird engine sizes. Check piston availability for what you want to do in the size you are looking to go to. No point in going to .010 or .020 if race pistons will cost twice as much as shelf .030 pistons. SRP and JE have a large selection of bore sizes for the 400. But I don't know if this is in your budget.
