I've been researching heads for about a 9:1 compression 434ci with a comp xe256h cam I want to build. The big question is how much headflow do you really need?
Most of the builds that I find are from early 2000's with 210-220cc heads. We have even better flowing heads available now. One article mentioned that whatever the original headflow for the engine was, increases that by 15-20% for a good street engine.
Now since you can build a 427 in sb or BB and the original BB came with 260cc intake runner heads. Does it make sense to run a 255cc cnc ported head on a 434 with a mild cam or would that be overkill? Comp makes that same cam for both sb and BB. Lift is .447/454 sb vs .480/.485 BB but all other specs are the same. Thoughts?
