440 swap
Thelittlecutlassthatcould
15
17
Howdy, so ive been toying with the idea of putting my chrysler 440 big block into my 87 cutlass supreme as i dont have anything else that i think it would fit into. So i was wondering if any of you guys know how it would fit in there, and what i would have to do to get it in there. Ive never done an engine swap before so i thought i would turn here before diving in
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
There is a least one other one out there, was in the Hot Rod Power Tour a few years back. Mounts and drive shaft will not doubt be custom and need some fabrication, trial and error.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Reactions: 9 users
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Fast is fast. Just get the drive line angles correct.
maxi426
Sep 20, 2018
87
87
You'd want to look at a pickup truck oil pan to move the sump to the rear
8,819
7,766
Yes, a rear sump truck pan will be needed.
81Regal
1,557
485
83
Terril Iowa
Do it! As mentioned above it would take some fabrication to make it work.
1320John$$$
951
2,043
Pennsylvania
Gutless cutlass with a slowpar Transplant that’s how hot rod and got started then along came the LS and made life easy for everyone well almost everyone
8,819
7,766
Some of us would rather douse our cars with gas and light a match then go the LS route. Problem with Mopars is limited decent transmissions, especially the automatic overdrive versions.
