442 Lightning Rods
MadDrOlds
39
15
8
Lots of discussion around this topic, but I haven’t seen a definitive statement: were Lightning Rod shifters offered as an option on the 1985 442?
Related question: on the 83-84 Hurst, was there a separate RPO code for the Lightning Rods?
Thanks, friends
old80cs
626
2,057
Massachusetts
As far as I know they were only offered in the ‘83 - ‘84 H/O’s not in any of the 442’s of the 80’s. No idea on the RPO code.
A universal Lightning Rod set could have been bought back then as well for any application, long since discontinued by Hurst.
69hurstolds
8,195
17,596
No separate RPO code for the LR shifters. The "over the counter" Lightning Rods were a tad different than the factory 4 speed ones. The H/O rods were darn near even across, where the speed shop versions had taller center rod for sure.
1985 442 had only ONE shifter availability and it was the stock single stick with the side pushbutton like every other Cutlass with a TH200-4R shifter in the RPO D55 console with AR9 front reclining buckets.
There were plenty of RPOS pointing to a specialty car, like trim deletes and VD6 and VD7 for painted bumpers and such, but the BIG RPO that made everything happen was the W40. It's also embossed on the body cowl tag.
Here's the SPID from my 85 442. Has every option available with the exception of the monitor lamps and block heater. Well, and the power moonroof since I opted for the T-tops.
And here's my 84 H/O SPID repro prototype. It's not totally loaded, but you won't see Lightning Rods RPOs on it or anything.
john87442
316
365
Geneva ohio
Just a follow up question if someone was to get a set of LR shifter and want to put it in a say 1987 442 with the stock trans, what else would said individual need to complete such a task? I believe there was a bracket and different shift cable?
OldsDad
72
57
Southwest Michigan 49102
In a month I will have mine done. I am installing Lightning rods from a 83 Hurst in my 86 442. I don't know exactly what I will need until I get started. You can do a search and buy some of the Obvious Stuff.
69hurstolds
8,195
17,596
You'll need to tear up your console center section to fit them in.
If you do a swap, it's not cheap if you use all genuine GM/Hurst parts.
john87442
316
365
Geneva ohio
Well at this point I’m in for a penny in for a pound!! Definitely would like to use all oem stuff if I could. I’m installing a new floor pan so does the hurst shift plate mount to the same as the 442 or is that different also? I do see OPGI has the shift plate and gaskets and I can mock it up with my old counsel. Craft custom in Texas does a decent job with Sheffield grey reconditioning along with the steering wheels. I just need to source the bracket and cable I believe.
69hurstolds
8,195
17,596
IIRC, as it's been 100 years since I had the LR's out, the hold down and support plates bolt to the same location bosses as the GM shifter did. I'd double check that, but I believe they're the same. So if you don't have the original mount tabs on the hump, you'll need to re-attach them.
john87442
316
365
Geneva ohio
Thanks for that 69hurstolds. you always have great information and detail. I was trying to do some more digging last night, found several needed items like the brackets and plates, gaskets but need to research the shift cable and if the linkage is the same. Lots to look up.
69hurstolds
8,195
17,596
Shift cable for the LRs is the late 70s, early 80s Corvette cable. It is different than any of the other cables GM has for the TH200-4R.
GM p/n 357746.
