455 rebuild
H/O84
181
44
So I finally pulled the trigger and bought a 455. Thought I was buying a motor that was nearly ready to run but it ended up being seized. Normally I wouldn't have bought it but when the seller realized it wouldn't spin the price went from $650 to $100 so I figured why not it was complete from carb to pan and I could probably get my money back somewhere. So after tearing it down I found that 2 of the cylinders have a rust issues. The other 6 cylinders still have some cross hatching left and almost no ring ridge. Inside the pan it looks really good. So far I haven't brought it to a machine shop but one person told me to sleeve the bad clyinders and the other said to bore it 30 over. What do you guys think it a better option?
-83MONTESS-
4,570
967
Bellevue, Ohio
I assume Olds 455? Either way a steal for $100. Hard to tell without seeing it but I would think a simple overbore would be in order before a sleeve would be. Sleeves generally are only used for severe damage that boring and honing can't clean up.
Kennybill
286
401
Braceville, Ohio
X2 for overbore and get new pistons. New cam bearings and decked. Hopefully the crankshaft is good at standard or 10 under. You didn't say what the "LETTER" is on the heads. (Before #1 spark plug)
MrSony
6,790
6,673
Des Moines, Iowa
^Seconded. What year/heads you have? Make sure you confirm what the bore size is already and look at the tops of the pistons. it could be already bored.
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
Oh ya, resize the connecting rods with new bolts. It's all about the $$.
Or even better, replace the soft forged connecting rods with aftermarket. A good idea for any motor seeing higher rpms. As far as boring, .060" over should be no problem, follow the machine shop's recommendation.
Clutch
5,183
10,900
Brick NJ
I think the best question is what do you plan to do with it? How much power do you plan on making? If it's just a driver you don't need a lot of aftermarket parts but if you want big power you'll need to build for it.
H/O84
181
44
It's. 72 block, standard bore, with a g head and a ga head. It has the n crank in it. Pistons have pretty much welded themselves in. Pulled the harmonic balancer bolt out with a breaker bar and a post from a stop sign on it and the bolt just barely decided to give way and the pistons didnt budge. Originally the plan was for new rings bearing and a cam but that was when I thought the engine was nearly ready to run. It'll be a street car that may see alittle track time but mainly a street car that has a good amount of get up and go. Will probably end up boring it, will get forged pistons and most likely new aftermarket rods, I want to be able to spray a 150 shot. What is the N crank limited to? Maybe alittle bit of head work but I will be saving my money when it's done for a set aluminum heads.
Clutch
5,183
10,900
Brick NJ
For specks go to 442.com
