Hello,
I have a gantry crane and plan on installing this rebuilt 4L60e (from 2003 Silverado 1500 RWD) with the torque converter and 5.3L long block as a bolted unit into my 1984 Monte Carlo. Are there different bellhousings out there because some people discuss removal of "ears" from the transmission, yet per my attached pictures, the ears seem pretty tucked-in on my transmission. Looking at these ears, which don't protrude much, from my perspective, I'm not convinced I need to grind them off. Please look at the pictures and set me straight.
Additionally, I plan on using the stock column shifter. Will I be re-using the "equalizer lever" (u-shaped piece) and all the hardware shown in this post: https://gbodyforum.com/threads/shift-linkage-question.56871/ ? Will I salvage this stuff from the TH250 and make it fit onto the 4l60e in place of the cable actuated lever that is shown in the picture? I see from other posts that I might need to add a spacer down on the bottom if I have clearance issues. I'd like to get the PRNDL working; I've read lots of posts about adjusting this linkage, but I plan to learn by doing/cussing. The Lokar kits don't seem to be better than the stock equipment because they require mods.
If someone thinks there is a no-brainer cable conversion for my column shifter, like a cave man can do it in two hours, let me know. I am grateful for any time savers.
Guy that rebuilt the trans, and put a 3.55 eaton posi in my 7.5" rear (I know) said that I need to be careful bolting the torque converter to the flexplate - he says I could c*ck the torque converter. He tells me to "pull the torque converter forward into contact with the flexplate using bolt with a few threads engaged". Not sure how to comply with that since the bolts in question are rather short and low profile heads. I was thinking that I could engage each of 3 bolts a few turns, then rotate the engine 120-deg to the next bolt and make a couple turns, then rotate, then a couple turns, repeat until time for torque spec. Any pointers? Basic mechanic stuff - I know nothing - everything is a discovery.
