NJ54880 said:ever heard of yates efi? they built a 62 nova with stock 5.3 with ls6 cam and intake with BW75mm turbo. very cheap build, i know less than five g's, ran low tens on an open rear end on 15psi. he said it ran perfect on 15psi stock block no problems at all. 18psi is when it grenaded. it made around 500 whp. yeah a truck may be slow with a 5.3 but thats like what, 4500 pounds? g bodys are over a thousand pounds less, they will not run the same as they would in the truck for the simple weight factor. and 6.0's are not $200 more than a 5.3 that i seen earlier on this post, as far as i seen. their about between $400 more and double the price of a 5.3. i will say, i do think it is a waste to build a N/A 5.3 if you wanna go fast in my opinion. you need more cubes. just what i think.
that post about the 200$ more meant he could buy an ls1 for 200$ more than the 5.3, a 6.0 for 200$ more than the ls1 and so on.
Yet again, fine tuning a cam with a turbo on an ls engine is not an easy task. In fact it's an ordeal. It's a very time consuming process if one knows how to go about it themselves, or would take a ton of money for a tuner to get correct. The money spent on gas while tuning alone would be a month + worth of gas for a sbc, tune up the carb and go driving. They're not telling you for the average joe it would also cost 800$+ in dyno tune and real time tuning for something like this. Yes you can get hit and miss through a mail order tune to make power, most people do great, some people don't have that great of results after they run too lean and burn a piston. In any case every time there are these posts with any decent 5.3 hp numbers, it's always been highly tuned. The whole point of my disagreeing with all these opinions is the guy in this thread wants a nice engine swap with driveability and power upgrades in the future. I saw no mention of gas mileage, it seemed he wanted power more than mileage. Almost any sbc built and tuned correctly can give 15-16 mpg highway. For the cost difference, I don't care if yall think there's a magic ball of ls power out there, for the cost difference to make a 400hp small block vs a 400hp n/a 5.3 will not return enough money in gas mileage for a long time.
..and to me a 500whp 5.3 for 5 grand on top of engine swap price is a bad deal. A 300$ nitrous kit and 6.0 swap will make that same power easy.
