5.3 Turbo to Regal Radiator Options
BuickBroke$
139
139
Phoenix AZ
Gearing up for a budget LS swap in my '85 Regal and will do GT45 turbo most likely. I'm wondering what most turbo LS guys on a budget are using for radiators and fans? Will a stock truck set up fit and be sufficient?
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
81cutlass
4,649
13,565
Western MN
A pickup setup won't fit.
4th gen Camaro or Dodge intrepid fans are easy to install on a budget and a replacement rock auto radiator from a g body or 3rd gen f body works well. Cold case and many other people make single pass direct fit 3 cores.
If you're ok spending another $200 Griffin makes a nice 19x31 that fits and is dual pass with both hoses on the passenger side and makes a cleaner setup.
BuickBroke$
139
139
Phoenix AZ
Great info 81Cutlass, thanks. With a turbo I’m thinking it makes more sense for a drivers side upper hose location to get the hose away from passenger side mounted turbo? Or is there room for clearance?
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Red Deer, Northern Montana territory
I am going log manifold and drivers manifold under engine crossover for my hot side. Stock rad with SN95 mustang e-fan, same as the ford Taurus. If the fan wont keep up I'll go dual puller.
How are you routing your hot side?
64nailhead
Goat Herder
Dec 1, 2014
5,708
12,215
Upstate NY
Is this a daily, Saturday nite red light racer, strip or what? How much boost? It makes a difference for a recommendation.
Turbolq4
1,732
4,207
Nampa Idaho
I have a stock 3?? Core rad from my elcamino in my 5.3 turbo Malibu. GT45 sits right behind the passenger side headlight. Fan is from a crown Vic cop car.
BuickBroke$
139
139
Phoenix AZ
Weekend driver, nothing fancy, not a lot of boost, just want something fun, reliable, with a little power. Will be 100% stock 5.3 except for Deca 60 injectors. Will most likely be an On3 76mm turbo. This is my first LS build and my first turbo build and I pretty much know nothing about either! Thank goodness for forums! Just trying to get most of the issues lined out before they pop up. I know so many guys have done this so most of it should be easy. I’m going to try my hand at building the hot side myself with stock truck manifolds.
