1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
5.7 TBI - high idle
Discussion in 'Engine / Swaps etc.' started by EdontheBeach, Mar 13, 2013.
Thread Status:
  1. EdontheBeach
    EdontheBeach Greasemonkey
    Feb 29, 2012
    150
    22
    Indian Rocks Beach, FL
    fellas - i have an 83 cutlass cruiser with a 92 350 TBI from a roadmaster. if i drive at anything over about 30-35mph, when i come to a stop the engine continues at a high idle (1200-1300) for 30 or 40 seconds after i stop before settling down to 750rpm. i've checked the gas cable and don't feel it hanging up. any idea what might be the culprit? this is my first TBI car, i don't know where or what to look for.
  2. olds307 and 403
    olds307 and 403 Royal Smart Person
    Oct 14, 2008
    1,799
    94
    48
    Melville,Saskatchewan
    Check your idle air sensor on the TBI. There is a setting procedure, it may just need replaced. I think your Avatar is a bit too much.
  3. tc1959
    tc1959 Comic Book Super Hero
    Dec 23, 2009
    3,354
    116
    Surprise AZ.
    Three things can cause what you are describing.
    1. A worn throttle shaft, This can be repaired by having new bushings installed at a Carb shop.
    2 the TPS or throttle position sensor is faulty or misadjusted. You need a DVOM to set it properly.
    3 The Idle Air Control motor or IAC for short is faulty or clogged up with carbon. This is the most likely cause of the high idle. It is located on the side of the T-Body and is very easy to replace. it just screws in. It's a good idea to clean the port with some carb spray before installing the new one. Also disconnect your battery for 3-5 minutes to reset the computer and let the car sit and idle for ten minutes so the computer can relearn the idle.
    I have no idea what a idle air sensor is. I have never heard that one before. :?
  4. EdontheBeach
    Feb 29, 2012
    150
    22
    thanks fellas - i'll try the IAC route ....and i'll change the avatar. it's not my intention to offend anyone; i thought she was funny actually.
  5. gwhiz
    gwhiz Greasemonkey
    Aug 21, 2012
    184
    clean the entire throttle body ou real good.i had a 91 tbi that was so gummed up the throttle plates would stick every once and a while.if that dont work look at iac valve.luckily all the sensors on that motor are cheap
  6. olds307 and 403
    Oct 14, 2008
    1,799
    94
    48
    Well sorry couldn't remember IAC :roll: . I kept thinking IAT, which I knew was wrong. Either way right part, wrong name. Clean out the passage really good as mentioned.
  7. EdontheBeach
    Feb 29, 2012
    150
    22
    the new IAC did it fellas. Thanks a Lot!!
  8. tc1959
    Dec 23, 2009
    3,354
    116
    Surprise AZ.
    Glad to hear it. I bet your car is a good runner with that TBI set up. 8)
  9. olds307 and 403
    Oct 14, 2008
    1,799
    94
    48
    Very cool. Your Avatar as a joke was fine :). The TBI is a very good set up.
  10. EdontheBeach
    Feb 29, 2012
    150
    22
    looks like i jumped the gun - i took the car out to run a few errands, within 5 mins. of leaving the house it was back to it's old way. 1200-1300 for 30-40 seconds when i come to a stop.
Loading...
Thread Status:
Share This Page
