5.7 Vortec w/3spd Manual Trans.
Clarmo
267
460
Ottawa, Canada
Has anyone put a manual trans behind an L31 Vortec WITH the mechanical clutch linkage?
I'm curious if the L31 motor has the provision for the ball stud on the left side of the block?
The 110hp V6 is coming out!!! The Iraqi Taxi is getting a heart transplant!!!
I've been acquiring parts all winter to do this. Ram clutch and 153 tooth flywheel, Edelbrock perf. RPM air gap intake, Holley EFI Sniper system, Aeromotive intank fuel pump, efi sending unit...and I just ordered a new long block from the dealership.
I just thought of the ball stud... I'll make it work either way.
clean8485
2,862
2,154
Ontario, Canada
I'm not sure about the L31 block, but I have an '87-'95 350 block here, and it has the threaded boss on the side of the engine block at the rear on the driver's side, just below the deck surface for the cylinder head, and above the oil filter mount. The block casting number is 14093638. Hope this helps. I'm interested in seeing your swap in progress and complete.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Is that the truck engine with no fuel pump provision?
Clarmo
267
460
Ottawa, Canada
I'll keep you posted.
Thanks
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
What is there a benefit going with that engine over a reg 350?
The Heads?
