5 speed shifter ball size
Sammieizzy
14
4
Hi I want to put a hurst handle on my 78 cutlass 5 speed
Does anyone know the thread size I’m used to the older 60s car
plus I would like to put a console in this any ideas
thanks
steve
carnutjw
624
1,469
If you just want to change the ball, there's more than one size available, need to confirm what your current thread size is. Browse the Holley website for balls or sticks=
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I use a thread pitch gage out of my tap and die set in cases like this. Stand by for metric…
Red78Calais4speed
136
229
Leominster, Massachusetts
Is the 5-speed in your car from the factory or a later conversion? The factory T-50 5-speed was available from 1976 to 1979 in the Cutlass models. The shifter used was an internal rail system with no exterior linkage. The stick was fairly thick and the shifter ball on top was a press fit, not a screw-on, unless the shaft was modified to accept a screw-on knob.
oldsmobile joe
2,067
3,053
mpls
both, my 78 salon and 79 calais, have threaded shifter shafts that i was able to mount new aftermarket knobs onto. i don't remember the thread size or pitch. the generic knobs came with the correct shift pattern and a selection of adapter inserts to mount the new knobs. i'll see if i can find more info or pics.
Sammieizzy
14
4
The transmission was changed to A tremec 5 speed from the factory 5 speed
oldsmobile joe
2,067
3,053
mpls
You will need to remove your current shifter ball and measure. I see you have a hurst shifter lever. idk if they kept it all the same or if there were different sizes.
carnutjw
624
1,469
Are you wanting a T handle?
Sammieizzy
14
4
Thanks everyone I took it off today just a nut locking in place
Thanks for all the help
