.50 taller ball joints?
Hutch949
37
2
8
Working on the 79 monte again.Still need the front a little lower.If I do the 1/2 taller ball joint on the lower ,does that mean I have to do the tallerball joint on the top?I have talked to a couple of shops and they have not heard of this.Will there be any problems getting a new front end alignment? What brand ball joint do you recommend and where should I purchase them? Thanks Hutch949
UNGN
3,048
3,264
Southlake, TX
Lower only will be fine. Proforged from Summit are $50 each with free shipping. No alignment issues and camber and toe will be easier to set and keep their settings because they will be more stable through the suspension travel.
UNGN
3,048
3,264
Southlake, TX
On average, how much does it change the camber? For better or worse?
With stock ball joints, when the wheels droop, they go negative about 3 degrees and when they go up, they go positive about 1 degree. This a a 4 degree swing in the opposite direction of ideal.
Ideal would be zero to slightly positive camber droop and negative camber when they go up.
Taller ball joints will turn the bad 4 degree swing into about a good 2-3 degree swing, so if they are zero at rest, they will go to about 1 positive at full droop and around 1 negative full up. How much it changes depends on the ride height and static camber, but the camber swing is definitely smaller AND better with tall ball joints.
If I had a G-body that could pull the front wheels, I would definitely put tall ball joints on it.
  • Informative
Reactions: 6 users
Ribbedroof
4,890
6,930
Wellston, OK
THIS is the kind of post I'd like to see more of....rather than just "you should do/use this", there is solid info to back it up.
Many thanks to you, UNGN!
Reactions: 13 users
oldsmobile joe
2,067
3,053
mpls
here you go, rockauto.com
High Performance
PROFORGED 10110048 {#88911524} Tall Lower Ball Joint; Greasable; Black E-Coated Finish Info
Front Lower; 0.50" Taller version for added dynamic negative camber.; 0.50" Extended Length Stud For Improved Performance; May Reduce Suspension Travel - Check For Binding After Installation; Requires Use Of Upper Ball Joint Part Number 101-10020
$42.79
Add to Cart
PROFORGED 10110020 Tall Upper Ball Joint; Greasable; Black E-Coated Finish Info
Front Upper; 0.50" Taller version for added dynamic negative camber.; 0.50" Extended Length Stud For Improved Performance; Installation Of Lower Ball Joint Part Number 101-10048 is Highly Recommended; May Reduce Suspension Travel - Check For Binding After Installation
  • Winner
Reactions: 5 users
timo22
550
1,072
St. Louis,Mo
UNGN ,
Let’s say you go with only the tall lowers. Are there any other changes you need to make. Tie rod connection, sway bar , dust shields? For just a street driven car, if a guy needs upper and lowers, does it make sense to just get tall lowers and stock uppers? Or just get tall for both? Once again, any changes need to be made or just an alignment? Thanks in advance for sharing you’re knowledge...timo22
UNGN
3,048
3,264
Southlake, TX
Tall lowers should fit with any wheel, but The Brake Dust Shield and the Lip of the LCA way need a little work with a $10 Harbor freight 4" cutoff wheel, to avoid hitting the arm/brake rotor.
Tall uppers can lead to a little more interference with wider (like 8"), smaller diameter wheels, but 17" larger wheels are fine. It many comes into play when turning. The Wheels can get close to the arms. 7" wheels or narrower are usually fine.
  • Informative
