500 rwhp 350 chevy in 1986 Monte Carlo
lilbowtie
3,460
3,965
Canton Mi
350 short block @ a swap meet $100.00
Re ring kit (Northern Auto) $100.00
Comps Cam 306S $145.00
Comps Cam lifters $100.00
Valve springs $90.00
Cam bearings and freeze plugs $30.00
Oil pump $40.00
Heads $300.00
Vic Jr $100.00
Harlin Sharp rockers $125.00
The engine has 550 HP 450 to the wheels - NOW I know the LS is a much more capable engine no argument (not for pennies) - but the old lilbowtie has merit
9,591
12,612
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
Oil pump $40.00
Heads $300.00
Vic Jr $100.00
Good points, I won’t disagree at all. It can be done. Either path will payoff in the end. I believe the swap itself would even out the end cost, but either can do it. Depends on the level of involvement a person wants to undertake.
Clone TIE Pilot
3,831
2,568
Galaxy far far away
Cam bearings seem to be a common problem on high mileage LS engines. Even our 45k 6 liter had issues. Not having a proven tune loaded for initial start and road test can be expensive and cause the issues noted.
I read that s partial reason for this is that most LS engines use cheap rolled cam bearings which are more failure prone. Even LSX blocks come with cheap rolled cam bearings, and many builders replace them with one piece bearings.
Turbolq4
1,732
4,207
Nampa Idaho
When you take a used one apart the bottom of the cam bearings are multicolored/worn out from dry starts with the weight of the valve train pushing the cam into them. The top of the bearings feel like 80 grit sandpaper.
6,793
6,678
Everyone is overlooking the fact that to take that much HP, regardless of what engine is used will require reinforcing the frame and body. G bodies can only safely handle up to 400 HP with factory bracing. More than that and you ard looking at boxing the frame, welding LCA mount gussets, bigger rear axle, etc. This is considering the op's car is in good shape and not a rust bucket.
Also, not sure about other areas, but around me, the junkyards just pull and scrap LS engines or sell them piece meal style. Plus there is the cost of learning an entire new family of engines that have nothing in common with classic gen motors in addition to buying adaptors, brackets, wiring and programing the PCM, and custom built parts like exhaust and driveshaft. Plus the only street legal LS swap for old carx is the Erod crate engine package, as normal LX emission systems do not work in G bodies. There are plenty of SBCs that last to 300k. It is pretty easy to make 400 hp with a SBC and vortec heads. 880 blocks are the best factory SBC blocks. LS engines are good, but you need to be an electronics wizz and a computer nerd to play with them.
Was just about to write about this.
