Ok so I'm goin to pull the motor in my Monte this winter so I can paint the firewall and clean it up some under the hood. My motor is just a stock l98 350 motor with the 4 valve relief pistons in it and the heads on it now are the 193 tbi heads, the car runs good and I can beat my buddies 88 iroc camaro with it,
But anyways while I have the motor out I want to port to heads so it will help flow, but then I remembered I have some 601 heads off my old camaro, I'm trying to decide which ones I should port and polish and use, I've talked to some guys and they are telling me to go with the 601 305 heads, it will raise my compression alittle and if I gasket match them when porting them it will help and out flow the tbi heads, does anyone think I shouldn't use the 601 heads?
