Thought I'd post my final fab work on the front seats. I originally made brackets to keep the 6th gen power seat tracks. Everything fit nicely until I installed my console. Ended up ditching the 6th gen seat tracks (too wide) and make some brackets for the seat base to bolt to original g-body seat tracks. Pretty easy with a welder and some flat bar stock. Basically 2"x17x3/16th" lengths, one end has a 2" piece welded on and the other 3". These 2 pieces were to shim the seat so the seat adjuster could work and also the seat frame itself is flat where the seat tracks are curved. Bolted the track in the car put the seat on to, marked the holes drilled and bolted them together. Also gave me a chance to mount the driver's seat rearwards a bit for some extra leg room. Going to keep the side plastic trim pieces with the switches etc in them for a more finished look, just need to trim the bottom off.
