7.5” 10 bolt disc brake conversion
Baker7888
567
97
Maine
Hey guys. I’ve been looking at the G body rear disc brake conversion kits. There are various kits available which seem to have various different bracket designs.
Do the existing drum brake shields need to come off and if so can the disc kit be installed after the axles have been reinstalled??
Streetbu
Know it all, that doesn't
May 22, 2011
3,659
11,196
Central NY
Yes dust shields need to be removed, and no, disc's can't be installed after the axles are back in. They need to be out to install the associated items for the conversion.
Ernest
606
720
Texas
If two disk brakes are good, four must be better..... whats wrong with keeping the drums for the rear, you need the majority of the stopping power up front, not the rear.
Baker7888
567
97
Maine
They are completely shot. And also have been sitting for 20 years. I prefer discs due to familiarity so am happy to ditch the drums.
64nailhead
Goat Herder
5,530
11,705
Upstate NY
Parking brake cables are not found in a kit that are the correct length. Calling bruisedbanana79
The driver side cable and sheath will be too short - BARELY. Unless of course you order a custom kit.
And most of the kits with Seville calipers will not allow for the car to be lowered much without notching the frame for the parking cable attaching point.
abbey castro
970
1,192
Harker Hts TX
Many of us have gone the cheap route with Camaro Rear Disk setups. Parts are easily available at the local 5 & Dime auto parts store as well as the major parts such as brackets, calipers and nut and bolts at the pick & pull. U Tube has bunches of videos on how to do it.
Baker7888
567
97
Maine
Good to know, thanks for the info
abbey castro
970
1,192
Harker Hts TX
E Cable cutting/routing is a fabricate it yourself. I tried the Seville setup and it was a disaster. Gave the whole setup to a friend who still hasn't installed it. Never could make the e-brake adjustment. Hit the frame as well. As you can see on my Camaro setup, I used longer bump stops to prevent the caliper from hitting the frame. This is with stock F41 rear springs!
Baker7888
567
97
Maine
Many of us have gone the cheap route with Camaro Rear Disk setups. Parts are easily available at the local 5 & Dime auto parts store as well as the major parts such as brackets, calipers and nut and bolts at the pick & pull. U Tube has bunches of videos on how to do it. View attachment 203016
By cheap route how much did this route cost?
Clean setup by the way, very nice
abbey castro
970
1,192
Harker Hts TX
Spent 548.00 for Ac Delco rotors/pads/e-brake shoes and caliper repair kits and AC Delco pads and a complete 2002 Camaro rear end. I used the backing plates, calipers and cable brakes w/nuts and bolts and the yard gave me back 75 for the remaining rear end.
