7.5 G80 posi differential cross pin
Flyers9928
Flyers9928
244
Mercersburg Pa
So I bought a eaton G80 posi unit with all the seals and bearings, from a friend. It was never installed. The problem is the differential cross pin is missing. I called the all the after market company's and nobody makes one for a 7.5 inch posi. I called Eaton direct and they told me to call the dealer. The dealer told me they only have a listing for an 8.5 posi, and that the only thing for a 7.5 specifically states that it's for open carriers. he said that its possible that the part number was left off when they updated the catalog, and that an open 7.5 pin may work. Anyone come across this ? any one happen to have one? Thanks in advance.
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,459
Socialist NY
I thought they were the same...........
Reactions: fleming442
Gonzo1970
Gonzo1970
810
I really don't know enough about Posi units to be helpful here.
Hell, I wouldn't even attempt installing one... thats a "gonna have that done" thing.
-Gonz
@BurnoutsandRotorblades
135
Las Vegas, Nevada
Go to the junkyard and grab one from an S10 or GBody and see if it fits. Cheapest option.
1983calais
1983calais
212
Tiffin, OH
If you bought a new setup, I’m assuming you’re replacing your existing one. Pull your pin and put it in your new carrier and see if it works. Got to start somewhere. Good luck.
Reactions: 1320John$$$
pontiac guy
pontiac guy
275
Royse City, TX
They are all the same. You can buy them at RockAuto even. I have a few of them you can have one for five bucks plus shipping
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
27,246
Kitchener, Ontario
for those cross pins I like using a brake bleeder wrench cause it has a 6 point 5/16" for the head of the pin
pontiac guy
pontiac guy
275
Royse City, TX
That's a good point about the six point wrench. which makes me ask did you get that bolts as well as the spider gears or did you only get the carrier?
pontiacgp
pontiacgp
Mar 31, 2006
27,246
Kitchener, Ontario
that's confusing, looked up G80 and that is the Gov Lok and had to look the old G80 to find the posi you have. I guess GM ran out of codes.... :wtf:
