I installed a g body 7.5 373 limited slip rearend and when I do a powerbrake sometimes it will leave 2 marks and sometimes only one tire will spin any suggestions whats going on with 1 and 2 tires spinning different times rearend is used?Thanks
Regardless of this, or any other rear end, the idea with the 7.5 is to not powerbrake or burnout unless you own a towing yard/junkyard and have plenty of free units to swap in.If I can recall this is my 3rd 7.5 rearend in different cars that does this I would hate to put my 8.5 in my daily driver I guess I will not be doing anymore burnouts LOL
Or like the stock 7.5" open spider gears. At least the open Monte SS ones have the larger, more even sized. 7 5/8" rear spider gears. Just switch tires side to side, every now and then to keep the wear even. The Torsen posi was the only decent 7.5" factory posi made. The rest are just too small and weak.Yeah they suck for the most part. Put any real amount of power or abuse behind one and they become a one wheel peel pretty quick. Over the summer I put a mint one out of a sub 100k MC SS, I think I got a solid month or two of nice burnouts before it went back to one leggers. At least they don't tend to create projectiles like the old gov-locks.
