7.5 rear differential, supposed to have a diff cover magnet?
fly_25
136
67
Is the rear differential cover supposed to have magnet on the inside? Mine does not have one. Does yours?
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Some did, some didn’t.
Are you concerned that yours doesn’t have one?
fly_25
136
67
I'm just maybe concerned that either I did have one, but fell into the gears. Or I didn't have one and the metal contaminated oil damaged some of the bearings and gears
ck80
Moderator
Moderator
5,742
9,111
Ours have. I guess it depends when and where the pan is from. If it did it would've been roughly where thy dimple is located IIRC.
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
If the gears or bearings are hurt, then the magnet is if no concern at this point.
Why did you take the cover off? General maintenance or is there a concern?
fly_25
136
67
General maintenance, fluid flush, new seals, new wheel bearings. Also notices that the pinion bearing has very little play, but it does wiggle a little bit. Is that normal?
64nailhead
Goat Herder
Dec 1, 2014
5,659
12,059
Upstate NY
Up and down a thousandth or two is ok. In and out is bad. Is the seal leaking?
