7 blade fan good upgrade?
MrSony
MrSony
5,553
Des Moines, Iowa
I've heard it talked about on here in good favor. My car, even with a new rad likes to creep up in temp at a stop. take off, it goes down again. the fan is an oddly sharp 5 blade i took off a 229 v6 at the junkyard with my 2 year old clutch on it.
olds307 and 403
olds307 and 403
5,864
Melville,Saskatchewan
Get the 4 blade solid fan and adapter Briguy bought for his 403.
565bbchevy
565bbchevy
7,442
Michigan
I bought this 6 blade clutch fan with aluminum blades along with a new thermal clutch for my Regal and it works very well.
Reactions: Texas82GP
olds307 and 403
olds307 and 403
5,864
w/killer results too
Second guy on the site with 403 in a G body to see a substantial drop with that 4 blade fan. I haven't seen over 195 even without a shroud in my 70 Cutlass.
Longroof79
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
10,666
Gainesville, Fl
I've been using a 7-blade Monte SS clutch fan with good results. Prior to that, a 7-blade Hayden flex fan. Noisy, but it kept it cool.
olds307 and 403
olds307 and 403
5,864
I do have a 8 blade fan off the 5.9 Magnum in my Dakota. Looks like it will fit the 307 Clutch but might be backwards.
Turbolq4
Turbolq4
1,625
Nampa Idaho
A fixed fan basically exes out any performance gain you may have realized by putting a 403 in your car to begin with.
Could put an auxiliary electric fan on the front. Use a heavy duty switch to control the relay and source the power from a circuit that's only on with the ignition so if you forget to turn it off then it won't matter.
Can keep a fan that has some concession to economy/performance and give it that little extra cooling capacity when needed without reverting to 1890s technology.
MrSony
MrSony
5,553
Des Moines, Iowa
As much as it cools, I am just not a fan of a solid fan.
Thread starter Similar threads Forum Replies Date
Rudy913 7 blade fan General Discussion 25
B SS fan New Users 4
M New member, longtime g-body fan New Users 6
A Help with fan & fan clutch Chevrolet Monte Carlo / SS / Malibu 4
FluoFerret Electric fan shrouds Cooling / Heating / AC 22
O Electric fan relay Electrical / Ignition / Starting 18
Longroof79 Fan belts -cogged vs. smooth General Discussion 14
SmokinJoe cutlass supreme upper radiator hose strap to fan shroud Oldsmobile Cutlass / 442 / Hurst/Olds 6
Fishbait17 Electric fan install Electrical / Ignition / Starting 14
Chuck Cole Oldsmobile V8 Fan Shroud General Discussion 7
pontiacgp Cooling Fan Switch Probe General Discussion 6
olds307 and 403 Best thread in fan switch Cooling / Heating / AC 15
Bri guy Electric fan setup Cooling / Heating / AC 33
dickeymoore Electric fan whistling Cooling / Heating / AC 5
8 GN cooling fan won’t turn on Buick Regal / T-Type / Grand National / GNX 9
pagrunt Storage of a good fan clutch for future reinstall Cooling / Heating / AC 5
olds307 and 403 Glad I am not a chevorlet fan or this would come home. General Discussion 8
Lukeschwtz 86 442 GM fan belt part number General Discussion 8
corvettez06 Recent upgrade G-Body Build Threads 10
bobby frillou Whats needed for radiator upgrade v6 to v8 engine General Discussion 4
@BurnoutsandRotorblades Easy E-Brake solution "LS Disc Brake" upgrade Wheels / Tires / Brakes 3
8 Power Mirror Upgrade How-To's / Knowledge Base 29
R MALIBU Carpet upgrade Interior 2
Clarkwb100 Blazer brake upgrade help Wheels / Tires / Brakes 16
S upgrade to bigger rear brake drums General Discussion 22
C Need quick help with brake line Blazer upgrade Wheels / Tires / Brakes 5
TURNA doing a C5 brake upgrade...Or use AC Delco parts......? General Discussion 5
Daca214 brake light switch upgrade General Discussion 21
D 2000 Camaro brake upgrade???? Wheels / Tires / Brakes 3
Diesel guy Sanden compressor upgrade questions Cooling / Heating / AC 1
T fuel door upgrade How-To's / Knowledge Base 2
