1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
700r4 good with 3.73 rear gears ???
Discussion in 'General Discussion' started by laman1982, Jun 9, 2011.
Thread Status:
  1. laman1982
    laman1982 Apprentice
    Mar 16, 2011
    95
    phoenix az
    700r4 good with 3.73 rear gears or not whats best :bump: ???
  2. kornball426
    kornball426 Royal Smart Person
    May 29, 2009
    1,130
    there's no answer to the question "what's best?" but if you want to run fairly steep rear gears like a 3:73, and you want to have any kind of highway mileage then you will need overdrive and the 700R4 is a good choice. It's basically a TH350 with an extra gear for highway mileage.
  3. laman1982
    Mar 16, 2011
    95
    phoenix az
    well thats what came stock with my monte 3:73 rear gears i see alot people running 4:10 or 4:56 rear gears i just wanted some opinions ?
  4. 9a pilot
    9a pilot Not-quite-so-new-guy
    Apr 20, 2011
    40
    6
    904 area code
    Yeah it's a good street gear. It's an even better street gear for a 2004r. The best all around street gear for a 700 is 3.42.
    At least in terms of the gear multiplication in 1st & for cruising in OD.
  5. woodss
    woodss Not-quite-so-new-guy
    Mar 15, 2010
    15
    Depends on your car and its use and your desires but its a good streetable setup.
  6. laman1982
    Mar 16, 2011
    95
    phoenix az
    STRIP AND STREET
  7. -83MONTESS-
    -83MONTESS- Moderator
    Staff Member Moderator Silver
    Nov 4, 2010
    4,197
    142
    Bellevue, Ohio
    For street and strip a 700r4 with 3.73 gears would be the ideal setup IMO. Get a nice shift kit and you'll be having fun in no time! If your not relying on the gears as much as the torque of the engine to get you moving then you could go with 3.42s or even 3.08s (maybe). But keep that overdrive tranny! You will regret it otherwise :mrgreen:
  8. laman1982
    Mar 16, 2011
    95
    phoenix az
    thanks for the info! but now i need posi with 3.73 gears do you what cars had them ? that would fit right up with my 87 monte carlo ss??
  9. -83MONTESS-
    Nov 4, 2010
    4,197
    142
    Bellevue, Ohio
    Look mainly for 85-88 Monte SS's. Thats where I got mine and they are less rare than alot of the other Gbodies that had them.
  10. patmckinneyracing
    patmckinneyracing Royal Smart Person
    Jan 18, 2009
    2,063
    36
    San Antonio, TX
    My rear end came from an 86' monte ss and has the auburn posi with 3.73 gears. Swapped out the stock ring and pinion for a set of Yukon 3.73's since the stock set chipped a tooth.
    I have a 700r4 with a 2500 stall. The car hooks great and accelerates like a bat out-a-hell.
Loading...
Thread Status:
Share This Page
