I have a 700r4 originally from a 1986 B body. It shifted really soft and I installed a B&M shift kit in the Heavy Duty & RV option with a QJ carb. It worked better, but still pretty soft on the shifts.
I moved the trans to another car with a more hopped up engine (GM Hot Cam) and a Holley carb. I bought another shift kit for the pieces to move it up to Street and Strip. It didn't work well testing and I since realized that a different TV bracket was required for the Holley. I think I have that fixed.
I had also installed a B&M 2400 stall convertor but it stalled at 1200 rpm. Over a year had gone by from the purchase, so the warranty was gone and I put the stock convertor back in.
In the B&M shift kit instruction it has a chart for trans fluid pressure. It doesn't specify HD or S&S mode. The chart suggests:
75-85 psi in Park,100-140 in reverse and 160-295 in 2nd & 1st.
I'm seeing:
150 psi in park, 240 in reverse, 150 in 2nd & 1st
The car isn't licenced yet and I tested it easy in front of the house and it shifted firm into 1st and 2nd.
Is this ATF pressure ok, or is something wrong and the trans will self destruct?
Pete
I'm seeing:
Pete
