700r4 trans swap
oldscutt85
Jul 14, 2007
70
34
Camp Lejeune, NC
im putting a 350 700r4 combo in and do i need to to get a new cross member or can the stock one get modified to work.i am not running a dual exhaust yet and i need to get the car done before i go back to okinawa in a week wich is were im stationed
First of all..Thank you for your services!!!!! Anyways, You oughta buy the Jegster crossmember from Jegs....should go in w/o any headaches...also try iceman racing they also have what you need!! 8)
the crossmember for a th350 or 350c ( from the cars made 84 and older mostly ) is a close fit but the mounting plate needs to be cut off and flipped to the other side for it to work. Unless you have access to a hoist and a welder ( transmission jack helps too ) it's just easier to buy an iceman or jegster pre-made for your application.
i went the cheap way and cut the crossmember,now i just gotta get the drive shaft cut.hopefully they give it back to me the same day.i wanna drive it atleast once before i go back.
