We have had a problem with what I think is the valve body in this transmission. We got the transmission from someone else, and when we rebuilt it, some weird shift kit stuff was done inside the valve body and separator plate. From what I remember the check balls were moved, some holes drilled out etc. We put the valve body back together the way it came apart, figuring it'd be fine. Part throttle crusing it has nice firm shifts, and doesn't seem to have any issues. Until you you floor it above 50mph, it won't down shift like it supposed to, it just kind of burbles along in 3rd-4th gear. The TV cable is adjusted properly, and the fluid is always full and clean. I'm thinking a stock valve body and separator plate will fix this issue. Then I can add another shift kit to that valve body, so I know exactly what is done to it. Anything else you guys can think of? Right now it only has 4500rpm shift governor, but I don't think that is the cause of this issue. Its been like this since we built it, it isn't hurting the transmission any, but now I'm finally ready to get to the bottom of it. You'll hear in the video it makes the 1-2 shift nice, the 2-3 is ok, and then it goes straight to 3-4.
