78-80 Cutlass hood weight
Discussion in 'Oldsmobile Cutlass / 442 / Hurst/Olds' started by Rktpwrd, Jan 5, 2017.
  1. Rktpwrd
    Rktpwrd Royal Smart Person
    Feb 2, 2015
    1,601
    2,680
    Calgary, Alberta, Canada
    Does any know off hand or could find out for me the weight of a '78-'80 Cutlass stock steel hood? Preferably without the hood insulator or anything on it, but will take what ya got.
    I'm in the process of selecting the correct weight rating of hood struts for my modified hood (I already know what it weighs), and want to compare it to a stock one.
    Thanks in advance.
  2. MrSony
    MrSony Comic Book Super Hero
    Nov 15, 2014
    3,584
    1,083
    Des Moines, Iowa
    I picked up my regal hood over my head and walked it 20 feet. Seemed like it weighed anywhere from 50-60lbs.
    • Like Like x 1
  3. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,802
    2,959
    Kitchener, Ontario
    #3 pontiacgp, Jan 6, 2017
    • Like Like x 2
  4. Rktpwrd
    Feb 2, 2015
    1,601
    2,680
    Thanks Steve.
    If those numbers are comparable with the '78-'80 hoods, that's great news for me as my highly modified scratch built hood currently weighs in at 52 lbs.
    A pound actually lighter than what's listed!
    That's possible due to the large amount of factory hood bracing and hood catch I cut out of the underside to create clearance for the 455.
    Mind you, that 52 lbs is with the hood still in it's raw unfinished form, without body filler, seam sealer, primer and paint, hood pin plates etc.
    I'm thinking by the time it's totally finished out, it should be about bang on or still slightly lighter than a factory steel hood.
    I did do a Google search before I posted, but came up with nothing for the '78-'80 models except weights for lightweight fibreglass race parts.
    I'd still be interested in hearing from anyone that has weighed or knows the weight of steel '78-'80 Cutlass hoods...
    Donovan
  5. pontiacgp
    Mar 31, 2006
    21,802
    2,959
    Kitchener, Ontario
    Donovan, High Roller was the member who posted the weight of the hood at 53 lbs. Why not message him to see how he weighed and it if the hinges and/or insulation was included or excluded..... I think the 53 lbs is accurate without the hinges and insulation.
    • Like Like x 1
  6. 85ss/85gn
    85ss/85gn Apprentice
    Jan 31, 2007
    76
    13
    8
    beaver dam,wi
    Stock steel hood is 55 lbs with latch spring and insulation. If wanted can also get the weight of a aluminum hood
    • Like Like x 1
    • Winner Winner x 1
  7. Rktpwrd
    Feb 2, 2015
    1,601
    2,680
    AWESOME, thank you!!
    No weight needed for the aluminum version, just the steel one was all I was after.
    As I mentioned earlier, I was just looking for the weight of a stock steel hood so I could compare it to my custom built one.
    So far it appears I'm about 3 lbs lighter with the custom one, which I'll take all day long as I had concerns it would actually be quite a bit heavier.
    Thanks for taking the time to respond, and for the info!
    • Like Like x 1
  8. L67ss
    L67ss Royal Smart Person
    Dec 8, 2016
    1,395
    215
    • Like Like x 1
  9. pontiacgp
    Mar 31, 2006
    21,802
    2,959
    Kitchener, Ontario
    what did you use to weigh it and are you sure it's accurate, if it is you should go to the thread I posted and post that weight for a hood
  10. L67ss
    Dec 8, 2016
    1,395
    215
    I was going off weight posted for 81-88 steel hoods. I had one fly off going down the highway once and had to go pick it up and run with it. Nearly crapped myself lol
Loading...
Similar Threads - Cutlass hood weight Forum Date
VFN W25 hood for 78-80 cutlass Oldsmobile Cutlass / 442 / Hurst/Olds Feb 11, 2017
Quick Question about 1979 cutlass hood? Oldsmobile Cutlass / 442 / Hurst/Olds Mar 1, 2014
'83 Cutlass Sedan hood replacement... Oldsmobile Cutlass / 442 / Hurst/Olds Sep 11, 2012
FINALLY A VFN W-30 Ram Air Hood for the 78-80 Cutlass !!! Oldsmobile Cutlass / 442 / Hurst/Olds Aug 24, 2012
84 Cutlass W/ buick V6 under the hood Oldsmobile Cutlass / 442 / Hurst/Olds Sep 15, 2011
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
