78' GP (454) air filter clearance issues.
Jay.D
17
12
St.Paul, Minnesota
Hello everyone I have a question I'm hoping someone has a answer for? Recently my oldest son picked up a real nice 1978'Pontiac Grand Prix. The car is origonally from Idaho, came with a 1979' 454ci GM truck motor, high rise intake manifold and edelbrock 750cfm 4-brrl carb. Which leaves very little clearence for a air filter. Anyone know of any aftermarket companys that make air cleaners to remedy clearence problems after putting big blocks in G-bodys like a 78'grand prix?
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
Do you have a drop base air cleaner on it ??
IIRC,even with a drop base and a Weiand Stealth intake and the stock flat hood on my Monte I still had to use a very low profile air filter,like a 2 inch or so.
A cowl induction hood will give you more room.
Guy
UNGN
3,048
3,264
Southlake, TX
An edelbrock carb is easier to get to work than a large holley, because even the the drop base might have to modified for bowl clearance.
axisg
2,685
2,354
YYZ
Another option is to ditch the hi-rise intake and carb. Go back to factory height intake and a Qjet and it will all fit under the stock hood.
454GrandPrix
429
818
Lehi, Utah
My 1980 Grand Prix has a 1999 454 underhood. I run an Edelbrock Performer RPM Air Gap manifold topped by an Edelbrock 1406 carb. I use a drop base air cleaner (dimpled for carb clearance) with a 3" air filter element. To keep from scuffing my chrome air filter lid, I did cut out some of the support ribs from the underside of the hood.
I would show pictures, but Photobucket sucks.
buick7332
350
589
N.E. Philadelphia area
You may have to do some research to confirm you have the correct motor mounts. I don't know about chevy motors but I'm sure for a Pontiac motor, 301 g body mounts are the only ones that will work.
MrSony
6,824
6,723
Des Moines, Iowa
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
They can but they don't on mine
  • Winner
