Hello everyone.Newbie here. i just bought a 78 monte carlo v8 305 and the car has no heat. The blower motor works on all speeds but its just blowing cold air. I let it run for 10-15 minutes and the upper hose is hot..I didnt check the bottom hose. I didnt check the heater core lines either as of yet. I was wondering if possibly the thermostat is bad? Should I change that first and see if that does the trick? Any help would be greatly appreciated. Thank you in advance
