79 Calais Tach
hangar401
hangar401
104
My in dash tachometer has not worked properly for years.It works but readings are off by bunch,like at 30 mph it reads at 2500rpm.Is this tach run by the alternator or distributor?
O
oldsmobile joe
1,314
mpls
distributor
H
hoffa65
286
Atlanta GA
There is a 6cyl/8cyl jumper on the back of the cluster. It has a spring type tab on it that after time cuts into the solder points it sits on after years of road vibrations the connection gets poor.
Pull cluster and solder a piece of wire or paper to the two connection points
It could a look so be the tach filter going bad, you should be able to remove the filter that is mounted to the fire wall to the left of the distributor
Reactions: fleming442
O
oldsmobile joe
1,314
mpls
thats good, neither can i. i checked my '78 and '79 factory service manuals, no diagrams or descriptions.
i did find these diagrams in my '80 manual. (see first pic)
and this from my 86 manual (see second pic)
then there is this from Al Gore's invention,
Setting the Tachometer:
The tachometer can be set to indicate RPM for a 6 or 8 cylinder engine by means of a jumper accessible from the rear of the gauge cluster housing.
Tach Jumper
1. Instrument Cluster Assembly2. Shorting Adapter
  • Calibrate the tachometer by installing the shorting adaptor in the hole that matches the number of engine cylinders (6 or 8).
or
  • This would be a good time to consider replacing the jumper with a soldered connection to eliminate possible future problems.
and this from you tube
O
oldsmobile joe
1,314
mpls
now i did find this on the monte ss forum.
i don't know if it pertains to an olds cutlass tach, but it may. i could see gm using the same components but on the tachs but on different circuit boards. so it the resistor on the monte tach has a high fail rate, so would the cutlass tach.
hope this helps you.
hangar401
hangar401
104
Thankyou everyone
Thread starter Similar threads Forum Replies Date
DUBWBC Update 81 Calais New Users 9
69hurstolds CUTLASS SOLD-Anyone needing NOS 1980 Calais/442 grilles? Restoration 12
hangar401 Calais dash Lights Oldsmobile Cutlass / 442 / Hurst/Olds 0
azmusclecar 1979 differences between Calais and Supreme model ??? Oldsmobile Cutlass / 442 / Hurst/Olds 10
DocG G-edi Master A little help here 84 Cutlass Calais A/C Wiring How-To's / Knowledge Base 6
azmusclecar Will this work on my 1979 Cutlass Calais? 10 inch wide rear with 4.5 backspacing? Wheels / Tires / Brakes 18
C 5 speed with Olds diesel in 1979 Calais? Oldsmobile Cutlass / 442 / Hurst/Olds 20
BigDaddyStu Odd Odometer Issue - 1984 Cutlass Calais General Discussion 11
Stupidquestionspro 1983 Cutlass Calais “The Cripples Cruiser” G-Body Build Threads 98
BigDaddyStu 1984 Calais Interior Color Question - Sand Gray Interior 8
RustBucket Pins on a factory tach Electrical / Ignition / Starting 4
M stock tach w/ LS engine question G-Body LS Swap 6
WanaBa442 CUTLASS WTB - Tach harness & filter Wanted 9
azmusclecar replaced tach, still doing same thing Electrical / Ignition / Starting 56
B Malibu tach confusion Electrical / Ignition / Starting 7
azmusclecar Replaced Tach, still reading high, do I need a TACH FILTER installed? And where does it go? Electrical / Ignition / Starting 4
azmusclecar ARGH! Why won't my tach reset to ZERO after each start? It seems to keep 500 or so rpms. Electrical / Ignition / Starting 10
