My century has a 301 v8 and I’m going to put in a sbc350 and turbo 350 trans. I know I need different motor mounts but besides that should it be a pretty direct swap?
I would be interested in your engine side motor mounts if you wanted to let them go. I’m putting a Pontiac 400 in my 86 Grand Prix and they are the key to make it all happen. I’ll try to send you a PM as well.My century has a 301 v8 and I’m going to put in a sbc350 and turbo 350 trans. I know I need different motor mounts but besides that should it be a pretty direct swap?
Will the stock fuel pump and lines work for a mostly stock sbc?Not sure if the trans cross-member would be different, even if you have the THM-200 now I think the crossmembers are the same. Other things to figure out of course are the exhaust and fuel lines that surely will need to changing or replacing going from the 301 to SBC.
