79 Malibu Steering Column
Max Headroom
420
389
I need to pull the no-tilt steering column out of my 79 G-BU. Haven't ever done it on a car this new. I have the column un-bolted under the dash. Can someone tell me what else needs to be done? I have all of the wiring disconnected except the reverse switch. Is there maybe a post on this? With Pics????
455'ed80Regal
467
211
Lincoln, MO
1- remove bolt & nut under hood by shift linkage and separate inner and outer shaft,
2- remove shift linkage at column
3- pull back insulation where column goes through firewall and remove 4 screws
4- remove underside dash panel
5- remove 2 nuts holding column to underside of dash
6- remove anything attached to column
7- remove column from vehicle.
