Hey guys I’ve been working on my wagon quite a bit lately. I’m just curious to know if anyone has ever successfully replaced the stock feed line with a pre bent 3/8 metal line without removing the body? A couple of the body bushing could be replaced on mine but overall they aren’t in terrible shape. I’ve already got the steering column out for repair and the saginaw trans out so I could zip the bolts out and lift the body off I suppose. I’ve only ever done this with GM trucks for brake lines and fuel lines but I’m assuming it’s pretty straight forward? I could try to clean up the frame and throw some POR15 on it as well or just buy some 3/8 braided line and call it a day. The car has around 130k miles on it and is in pretty decent shape. It’s been parked in a garage and hasn’t moved since 2003. The original fuel line is still in pretty good shape as well but I’ve already got a new fuel tank and replaced the electric pump with a mechanical one. I guess if I do go the route of lifting the body is there a place that anyone recommends for body bushings? Thanks for your time.
