I just purchased a non posi 3.42 8.5 out of a 86 GN. I have a posi 10 bolts out of a 1979 trans ams 323 ratio. Will the posi carrier out of rhe TA rear work in the 86 GN rear end. Not sure if it's a 28 or 30 splines
Sorry, I have two rear ends out of 1979 trans AMS . Both are 323 posi342 is a series 3 carrier 279 is a series 2
342 gears wont will on a 279 carrier
3TJJust curious, what is the code stamped on the axle tube ? TP or TJ ? Mine is stamped TJ Ana has a Posi. Different sites show conflicting info....timo22
