8.5 rebuild question
bertscova
101
36
Im rebuilding a 86 olds 442 373 lsd. The ring and pinion look to be in excellent condition. How much power can the factory gear set hold up to. Whats in car 450+ hp 383 stroker th350 2800 stall. Mickey Thompson street ets. Wont see the track often. When there will be footbrake off line. Just wondering if i need a better gear set
Bonnewagon
Lost in the Labyrinth
10,563
14,293
Queens, NY
My buddy has a 3:73 posi 8.5 rear in his '77 TA. It has lived behind a very strong worked Pontiac 400/T-350 for many years. Even with his Italian temper. His complaint is he can't go on the highway with the 3:73's.
Michael Watts
418
201
I have a 1979 Z-28 Rs with a 500 Hp supercharged 377 small block Chevy. I just upgraded it with a Moroso "Brute Strength" posi ,Chevrolet 3:42 gears .Mosier 30 spline axles. With no issues.An 8.5 10 bolt is just as strong as a 12 bolt when built with the right parts.
spidereyes455
784
1,637
Northeastern PA
Lots of turbo Buick guys running 11's and even into the 10's with not much more than aftermarket axleshafts.
bob64
713
674
Niagara Falls, Canada
Worry about torque more than Horse power, torque will bust stuff up.
I got a Camaro, the engine in it now started as a stroked 496 with 602hp/513tq with a 8.5 an 3.73 gears an then l added nitrous an better heads++, an it's still holding! Transmission is build (4L80E) full Manual an it bangs between gears if you let it, so l think your good to go!!!!
