8.5 swap ??
bertscova
bertscova
Jun 27, 2015
83
36
#1
Hey all I'm getting ready to swap out the 7.5 for a 8.5. I have umi upper and lower control arms along with a umi drag sway bar kit. I also have the drive shaft needed for the swap. I have a general knowledge of how to do it but was looking for some suggestions that might make thing go more smoothly.. I also dont want to send a coil sailing through the neighbor's sliding glass door Haha. Car is a 79 Malibu
KCP
KCP
184
331
Bavaria, Germany
#2
Couple easy steps to follow:
  1. Wrap 8.5 and corresponding driveshaft in foil.
  2. Strap it to a pallet.
  3. Send it to me.
I'll take care of it.
TURNA
TURNA
6,574
8,448
Socialist NY
#3
Unbolt remove install its that easy
The rear springs wont shoot out unless your car is 2 feet high in the ass
Probably the most annoying thing will be the e-brake
bertscova
bertscova
Jun 27, 2015
83
36
#4
  3. Send it to me.
I've got quite a bit of time and money tired up in it. All new bearings and seals. Moser axles rebuilt factory carrier with all new spiders, clutches and a heavier spring. New ring and pinion ect..
michmalibuman
michmalibuman
541
555
#5
Sounds good should last for a long time.:cool:
bertscova
bertscova
Jun 27, 2015
83
36
#6
TURNA
TURNA
6,574
8,448
Socialist NY
#7
If you use a hose clamp like this it is alot easier
proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2Fxq90%2F924%2Fs5mfoC.jpg&hash=67d22445069f79fb5930f051ead9054e
proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2Fxq90%2F922%2FDa0y15.jpg&hash=339e607ba4163b6f2865b7ce88939227
bertscova
bertscova
Jun 27, 2015
83
36
#8
I'm just taking the ebrake loose from the rearend side and not touching the rest. Same cable for both
TURNA
TURNA
6,574
8,448
Socialist NY
#9
Yes the pic is just an example of how to use the clamp
pagrunt
pagrunt
3,354
3,650
Shelocta, Pa
#10
If you're going to replace the cables on the axle might as well go all the way to the pedal.
Similar threads
