MALIBU 80 malibu aftermarket turn signal
CutSupreme
5
NE Illinois
Hello all! Long time looker first time poster! I think this is the right spot for this post hopefully.
I've got an 80 malibu I'm putting a trick chassis steering column in which requires an aftermarket turn signal switch. I'm going to be using the motion raceworks switch but I'm unsure which wires off the column harness I have to use. Any input is appreciated. Thanks for any and all help!
CutSupreme
5
NE Illinois
Any input on this? Or should I post this in another section?
Thanks!
ELCAM
936
953
The factory switch is fairly complicated and cannot be replaced with such a simple switch without some relays, diodes or adding wiring to the circuit.
With relays something like this.
To me the simplest way would be to use a GM turn signal switch which will require you to make a mounting bracket and housing for it.
CutSupreme
5
NE Illinois
I really appreciate the info and response! Thank you!
565bbchevy
9,363
12,020
Michigan
