81-88 cutlass hood
Trader history for 88 Gutlass (0)
88 Gutlass
88 Gutlass
34
Ga
I am looking for a cutlass hood that doesn’t have the chrome strip in the middle of the hood, or a 442 hood. Needs to be close to Ga
QS442
QS442
291
DE
I have an Hurst Olds hood. I'm located in DE. I can ship, pm if you are interested.
88 Gutlass
88 Gutlass
34
Ga
Shipping would make it not worth it, unless it is dirt cheap
O
Oldsmbl
16
Gas is cheap. Take the drive to Delaware. You will probably make a new friend at the same time.
Reactions: Eddie Cutlass
69hurstolds
69hurstolds
4,004
I'm not sure if you're after an aftermarket hood or a stock style hood, but GM only made 3 part numbers of hoods that will fit your car. Mostly steel, and some were aluminum (different part number). And both had provisions for some sort of strip in the middle, be it chrome strip or painted filler strip (H/O). The ONLY difference between the H/O hood and the regular hood is the H/O hood had one hole that was left unpunched which would land directly under the scoop. That changed the part number for that hood. Other than that, they were basically the same hood.
You can put an H/O scoop on a regular hood, just have to remember to plug that hole under the scoop.
