That rear trans support looks familer, there's not a truck at the Gap missing a wheel chock is there?
Haha, there's plenty of chocks.That rear trans support looks familer, there's not a truck at the Gap missing a wheel chock is there?
I dont have the pin lengths, but, you should shoot for .060" with a stock style servo. I have the CKP billet servo, and the instructions called for a larger clearance, .120" if I recall. .13-.15 is huge. There are also pin extenders you could use, but welding some metal on the tip is cheaper.
I have welded material onto the tip before, with no I'll effects. It's possible your band is wearing, or maybe a broken cushion spring in the 1-2 accumulator.
Sent from my SM-G960U using Tapatalk
Post your results, you can only bandaid a band so much. Also, is your TV cable set correctly?I had the accumulator apart to cut down the stock governor to GN spec so no bad springs. I think it was out of spec from the factory a bit and the band has worn.
I measured it better last night and it had .16" of movement. I welded .1" from your recommendation and its to .06 now. Hopefully its better!
Thanks!
No ls in this one, the turbo 6 keeps it interesting. Also, I thing your wheels are wided, but no matter, these wagons look bad *ss with 12+" wide rear tires.
