BUILD THREAD 81 Buick/Olds Turbo Wagon 02/15/2024 More Parts!
liquidh8
Took it all back apart, checked the iron support rings and the teflon scarf seals on the input drum.
When I check that hole on the input drum the piston pops up, but I get air out of the cooler line and the center hole of the input shaft. I'm not sure this is supposed to happen?
I checked it all before assembly, I dont Remember that happening.
Sent from my SM-G960U using Tapatalk
liquidh8
So after so.e careful inspection, it's the teflon rings leaking some air. I've read a ton of threads and it seems to be common when bench checking with air. The piston pops up and down no issues.
liquidh8
So, they'll seal with fluid? Can you wet them and the bore to make it work?
I was reading, even in the ckp book, that they leak. I hit a few threads and chris chimed in, where he said pack the groove as with grease and leak check k to ensure there were no other leaks, I did and it was fine. So those teflon seals leak. I even stole the solid seals from the Input shaft, and not really better at all.
So, I measured all the seals, i had 6 laying around, and used the thickest. It's much better, but still leaks some air.
I am now on the front selective behind the pump. I have a total of .036", minus the other measurement (I wrote it down) and I have. 010" with the yellow washer. The ckp book calls for .003 to .006. So I ow need to get a thicker washer it seams.
liquidh8
So I ordered a new yellow, and a light blue from ckp to take up .005" play. My yellow is on the thin side and a bit black looking. I could probably get away with the
010" play, but I managed to get this far making everything in spec for the ckp manual. ATSG spec's are broader and looser.
liquidh8
Revisited the trans, got the light blue washer in there, gave me the .006" total I need.
Torqued the front pump down, the governor housing, and a few other odds. Now, I have to yank the trans in the car out to get the valvebody.
Then final assemble and install.
liquidh8
Pics
Reactions: 5 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Cleanest trans I ever seen!
81cutlass
4,647
13,561
Western MN
You don't have in your books what lengths GM made for servo pins you have do you?
I have an 84/85 GN servo in my turbo wagon and it flares the 1-2 shift bad. Im sure the band is wore but im kinda band aiding it. Hope that if I dial it into .060 or so I can tighten the 1-2 shift up a bit.
Checked the clearance on the servo piston last night and it was like .13-.15", its supposed to be .06-.1" from what I read. That align with what your doing?
I have a 3 groove servo pin now and I know they have 1 and 2 groove pins that are either shorter or longer. I might just weld .06" or so onto the tip of the pin and regrind it.
liquidh8
I dont have the pin lengths, but, you should shoot for .060" with a stock style servo. I have the CKP billet servo, and the instructions called for a larger clearance, .120" if I recall. .13-.15 is huge. There are also pin extenders you could use, but welding some metal on the tip is cheaper.
I have welded material onto the tip before, with no I'll effects. It's possible your band is wearing, or maybe a broken cushion spring in the 1-2 accumulator.
