81 el Camino won’t shift out of first gear
Red1500
n00b
Apr 17, 2022
2
Hello everyone,
My friend and I did the shocks and valve gasket covers on my 81 el Camino,
And now my car won’t shift out of first gear,
Any insight to maybe if I disconnected or broke something I can’t figure out?
Thanks
ELCAM
1,123
1,270
Going to guess it is a TH 350 or another modulator controlled automatic transmission. You likely accidently disconnected the vacuum line from manifold vacuum to the modulator valve while doing the valve cover gaskets.
Usually comes from where the yellow arrow points, a rubber hose to a steel tube that goes down to the transmission,
airboatgreg
2,867
3,115
With engine off stomp the gas pedal to the floor a few times. May be a stuck kickdown valve
Red1500
n00b
Apr 17, 2022
2
Thanks for the help,it actually was a hose underneath at the transmission that came loose,I will post a pic in a bit!
I had no idea a hose could have anything to do with the transmission
