83-88 Monte SS Exhaust Route
MechMan
337
139
Kingsport, TN
Does anyone have a picture of the exhaust route on a 83-88 Monte Carlo SS? I will be wanting to run true duals when I start my project and would like a picture for reference so i can map out how I am going to do it. I Will be swapping out the motor for a LQ4 block but not sure which transmission I will go with.
79 USA 1
1,063
2,036
Cheektowaga, New York
Are you looking for just from the cat back or from the manifolds/crossover back? I'll try to get some shots from under my 88 SS this weekend. Has a Torque Tech 2 1/2 cat back system.
MechMan
337
139
Kingsport, TN
I am going to replace from heades back. I will be swaping out motors so I will be starting fresh.
axisg
2,685
2,354
YYZ
SS and frankly every G body ran a cat back system from the factory so anything with dual exhaust is going to be custom anyways
81Lcamino
17
10
Just replaced exhaust in my 81 El Camino with 2-1/2" Pypes dual for G-bodies. Swapped the crossmember for G-force dual cutout rather than cutting, boxing, etc the stock single crossmember. Added benefit of switching crossmember, despite cost, was really solid extra strength for frame/body. Don't need to pass smog here so no need for cat converters. Except for some work needed to connect Pypes to headers, was a very straightforward swap. Summit even shipped the exhaust kit without added ground freight for oversize.
454GrandPrix
429
818
Lehi, Utah
Well, my car is an '80 Grand Prix and not an '83-'88 Monte Carlo... but my exhaust kit is designed for a Monte Carlo SS so I guess I still count. This is the Pypes dual 3" system with x-pipe, attached to long tube headers which are hanging off my big block Chevy:
HTH
  • In Love
81Lcamino
17
10
That looks nice GrandPrix, mine looks much the same with crossmember, just don't have a picture to post. I'm running a sbc 350.
timbo512
Feb 27, 2018
65
101
How do you like that setup? Looking to do the 2.5" on my 350 install. I want to do the behind wheel versus straights. Is it too loud in the cabin that close up?
454GrandPrix
429
818
Lehi, Utah
I am very pleased with this setup. Having the pipes face this direction creates nice sound reflection when you're next to a Jersey barrier, or when going under an overpass, or when another car pulls alongside at a red light, etc.
No, definitely not. If anything, I wish this setup were a little louder. Maybe it's the x-pipe; perhaps its the straight-through muffler design I chose. Either way, there are times when this is too quiet for my tastes (and I never thought I'd say that about a dual 3" system).
On the plus side, at least I don't get a headache from noise/drone while cruising down the highway.
MechMan
337
139
Kingsport, TN
Thank you very much for the pictures GrandPrix. They are extremely helpful. Other than the cross member was there anything else you had to change or modify to fit the pipes?
