565bbchevy said:
I am going to look at a 83'
Buick Lesabre 4 door and all I want is the drivetrain for another project (more on that later) but I am wondering what other parts will work on a Gbody such as the ac/heater case?
Anything that you know will fit or would be worth the effort to modify to fit, maybe rear end?
Headlights, basic underhood mechanical parts, various hardware...not much else. The wheels generally aren't even the same, as the G-body used a 4.75" bolt pattern and the B/D-body used 5" bolt pattern if I'm not mistaken. Rear brakes are different designs, You can swap batteries, but B/D bodies originally used group 24 (top post) or 78 (side post) large batteries whereas the A/G used group 75 (smaller).
It would seem there would be a lot shared, but very few parts are a direct swap. The '77-'96 B/D body has much more in common with the '73-'77 A-body, I've even read on several occasions that the downsized full-sized cars were just slightly revised and rebodied intermediate cars (i.e. 1973 Malibu=1977
Caprice). The A/G body in 1978 was basically all new, and the S-10/Astro introduced a few years later was derivative of them, at least most of the chassis (firewall forward/brakes. S-10's used the group 75 battery as well, but they tend to have a battery tray that won't allow a bigger battery to be installed.
Heater and A/C systems are completely different from what I've encountered. G-bodies have the blower motor on the passenger upper firewall (wheel down). The B/D body has it turned the other way (wheel up) and down inside the car under the glove box by the kick panel.
