83 Cutlass Baer Brake System
edmck82
21
Washington DC
Piggy backing off another thread. I had seen two t-types in a GM high tech perf mag with Baer brake systems installed. The kit looks interesting and modern. Has anyone utilized them with their own application?
Wouldn't it be a good idea to upgrade the master cylinder , etc. , since you'd be moving up to a 4 piston caliper? higher fluid volume ?
Spindel/Axle mods necessary?
jerrycad472
264
16
Detroit, MI
I have been investigating the Baer Brakes also. I am calling them this week to ask some questions. One is whether a new master cylinder is needed, I will post the answer when I get it. I do know that at least some of their systems require the use of Caprice Spindles (b-body?) But I am not sure if all if them do. I think the ones that do, come mounted on the new spindles.
edmck82
21
Washington DC
Cool ! Let me know . From what I read from the application guide , this kit should work for all G-Body applications. Rear disc conversion ?
Cheers
