84 Buick Regal/5.3 PS issues.
illegalRegal
7
Ok, I have read about this issue 100’s of times and almost every thread I read is slightly different from my issue. My ps pulley is pressing up against the gear box. I have a 5.3 bolted to a 4l60E, G Force crossmember, G Force trans adjustable mount. When I push the motor back as far as it will go, it throws the crossmember bolt holes off with the frame holes, but then it has clearance with the pulley. When I set the crossmember to the correct position it wedges the ps pulley into the box. Can I make new holes on the frame or do I need an aftermarket bracket kit for the alternator and ps pump? I’m using all stock truck accessories. Thanks
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
I just put a Dirty Dingo PS pulley; 5" diameter down from the 7". It helped the clearance on the steering box.
81cutlass
4,645
13,561
Western MN
Frustratingly nobody puts LS engines in the same place. Some people put them forward and low, some up and back.
I home built my own mounts and have a stock truck PS pump pulley. Mine clears with 1" to the PS box.
Depending on the mount you can potentially slide the mounts back or use a different set of holes.
People use a 3.4 grand am PS pulley or the one off a 5.3 gmt360 chassis (TBSS, envoy denali or rainier) that is smaller.
illegalRegal
7
Welcome to the forum. Looks like this is your first post. If you would have used the Holley system you wouldn’t be having this problem. What motor mounts are you using?
I used these mounts from EBay
illegalRegal
7
Thanks I appreciate that. So with that being said, I would probably need to use different holes on the frame mounts? Do the crossmember always go in the area where the holes are made from the factory?
64nailhead
Goat Herder
Dec 1, 2014
5,695
12,175
Upstate NY
Those mounts look to have a slotted hole for the bolt. I can't say that I like that because it could very easy to get the motor c*ck eyed/tilted. That might be some of your issue. How much clearance do you have between the bellhousing bolts and the firewall? If much more than a 1/2-3/4" on the driver side near the pinch, then that's why you're having interference.
The solution is to do whatever works - raise the engine, slide it back on, smaller pulley, etc. Whatever works is the solution and is easiest for you. Personally, if I were in your boat and the swap is completed other than this issue, then the smaller pulley would be for me - way easier that pulling the motor and trans to re-orient everything.
Built6spdMCSS
5,793
9,664
Florida Beach
You haven't read very much honestly, this was solved years ago. With the above posts showing the lack of information on what I have put out a long time ago, come on people....
TRUCK SMALLER POWER STEERING PULLEY: DORMAN 300-201, 300-202 is the metal pulley.
BOOM.
Big HUGE post, the first one in the sticky's in this section...
Can lead a horse to water but I guess you have to jam their skull in the bottom of the trough to get them to drink.
64nailhead
Goat Herder
Dec 1, 2014
5,695
12,175
Upstate NY
BOOM.
That’s harsh dude, but unfortunately correct.
It’s the world we live in. I need the answer with no research and knowledge gained in 30 seconds or less lol.
  • Winner
