Hello, my 1984 cutlass is showing codes 15 and 24. My book says that 15 is the coolant temp sensor. My question is, which sensor is it talking about. The left one, or right one? from having popped the hood standpoint. I am not sure which goes to gauge and which to ECM. Furthermore, which replacement part do I get? Autozone only lists one coolant sensor. My uncle says that can be used to replace either sensor. Is this true?
Also, I lost the screw that fastens the vss to the back of the speedo so i'm sure that's why code 24 is coming on
