I swapped in a tilt column from an ss.im still going to use the column shifter and indicator in the cluster for now.everything is together but I cant get the shift indicator to work at all.it seems as if the wire that clips to the bowl is way too long or something.to line up properly the wire has to clip on the bowl way down by the bottom wrapping half way around the column.am I missing something here?does it wrap around a clip or something else I don't see first or does it go right from the indicator to the column bowl?
