S
Hi everyone! Blower motor still working great ! Got another problem.
Would anyone know about the rear defrost system on an '84 Regal Limited? It has a rocker toggle switch. It is a temporary touch type meaning it does not stay in any on or off position. For the 20 years I have owned this Regal it always worked however sometimes I would have to tap it a couple of times for it to come on. There is a light that comes on when it is ON. Now it does not come on at all. Is there a fuse or relay I should check on the fuse block? If so, does anyone have a pic. of the proper fuse block so I can zero in on the right fuse or relay to check? If a relay, how do these relays come out? Just so you know I don't think there is any problem with grid or factory wiring. I NEVER changed anything or cut any wires. Any help would be appreciated. Thanks !
p.s. It may be the relay, I am seeing a photo of one and it appears it is NOT on the fuse block. Under the hood maybe? Because it seems there is a plug in harness to it???
