85 442 vacuum
J
Jovanees442
n00b
Sep 22, 2019
Ok guys new to the forum and need some help with my vacuum lines and smog pump. Hoses are everywhere and some are lost and cracked it's a mess. Was wondering if theres a way to bypass alot of them
DoubleV
DoubleV
2,139
83
Medina Ohio
Question is a bit too open ended. What specifically do you need/want to do?
Reactions: fleming442
500/600
500/600
801
West Virginia
Depending on what is allowed in your area lose them all. You’ll likely end up with three or four that are required for something.
J
Jovanees442
n00b
Sep 22, 2019
I just want to be able to drive it until I'm able to afford to swap it with something bigger
J
Jovanees442
n00b
Sep 22, 2019
Yea I'm cali I feel like it's the most strict state on emissions but I'm not worried about that right now just to where um able to drive it and it be able to get me around town
DoubleV
DoubleV
2,139
83
Medina Ohio
Then for now just replace all the vac lines. Your emissions decal shows you how every line is routed. Yes there are some you don't really need but for now just keep it stock.
Reactions: 85442/86buick
Thread starter Similar threads Forum Replies Date
69hurstolds 442 Caveat Emptor- 442 door emblems on fleabay General Discussion 1
Kelvin's80442 Front suspension,crossmember,hood 80 442 Wanted 8
M Newish to the forums 85 442 New Users 12
Kelvin's80442 80 442 full powertrain swap Oldsmobile Cutlass / 442 / Hurst/Olds 46
Injectedcutty HELP Need to rebuild my 8.5" boys! Transmission / Rear End / Driveline 47
Erika Lee 442 86 442 Chrome Strips General Discussion 20
QS442 New 85 442 Oldsmobile Cutlass / 442 / Hurst/Olds 8
H Questions on parts for 87 442 front turn signal gasket and wiring cover Oldsmobile Cutlass / 442 / Hurst/Olds 2
S 88 cutlass lv2 442 value? Oldsmobile Cutlass / 442 / Hurst/Olds 30
JAMES L EUBANK 1985 White 442 Wanted 0
Ribbedroof 442 86 442 bargain - OKC General Discussion 5
AZRegal Various olds 442 emblems G-Body Parts For Sale / Trade 3
Red78Calais4speed 1987 Olds 442 200R4 G-Body Parts For Sale / Trade 2
5950NewEra CUTLASS Wanted 84 442 (Air Dam bumper cover) Photos, Videos, etc. 12
J picked up a 442 parts car today... OFF TOPIC 65
Jmac 442 1985 Oldsmobile 442 rear glass lower molding help How-To's / Knowledge Base 3
P 1985 Olds 442 - 36k original miles G-Body Cars for Sale / Trade 9
Kwyk85_442 Looking for a center console for my 85 442 Interior 4
565bbchevy Nice 87' 442 on FM for $13,500 General Discussion 14
blk7gxn Olds 442 For Sale---Not mine General Discussion 3
E 86 442 8.5 POSI rear G-Body Parts For Sale / Trade 25
4 86 442 Rear Window Lower Trim Clip???????????? Body / Trim / Paint / Glass 6
abstracts18 G Body Front air dam/splitter help Oldsmobile Cutlass / 442 / Hurst/Olds 3
69hurstolds CUTLASS SOLD-Anyone needing NOS 1980 Calais/442 grilles? Restoration 12
V '87 Olds 442 Spline count? Transmission / Rear End / Driveline 2
H Need 87 442 front bumper cover decal and stripe Oldsmobile Cutlass / 442 / Hurst/Olds 5
Jmac 1985 Oldsmobile 442 Rear glass lower reveal molding clips Oldsmobile Cutlass / 442 / Hurst/Olds 6
J 78 442 Speedometer Cable Retainer Interior 3
ssaamm77 Thinking about selling 87 442 parts Oldsmobile Cutlass / 442 / Hurst/Olds 34
S 86 442 recliner handles Oldsmobile Cutlass / 442 / Hurst/Olds 4
SupremeSpeed 442 rallys Wheels / Tires / Brakes 18
Furtrader Need 1980 442 bucket seat replacement covers Interior 2
AZRegal 85 442 Oldsmobile Cutlass / 442 / Hurst/Olds 43
Lukeschwtz 86 442 GM fan belt part number General Discussion 8
H 79 442 for sale in Atlanta GA Oldsmobile Cutlass / 442 / Hurst/Olds 3
565bbchevy 86' 442 with t-tops new posting 6-1 on CL Detroit Oldsmobile Cutlass / 442 / Hurst/Olds 4
M Vacuum Canister Reservoir Wheels / Tires / Brakes 4
W Vacuum selector switch Cooling / Heating / AC 6
G 1980 Malibu classic landau chev SB 267 vacuum routing General Discussion 13
harvtown REGAL need vacuum hose diagram 1978 3.8 dueljet Fuel / Air / Boost / Emissions 1
P Detailed vacuum hose pictures General Discussion 6
Z Vacuum Ball General Discussion 4
rogus Where to buy vacuum pod 81 Elky Cooling / Heating / AC 0
Buford T. JuSStice No vacuum to HVAC system, stays on defrost Cooling / Heating / AC 17
kustomkyle Replacement air cleaner vacuum actuator, 307 Olds. Fuel / Air / Boost / Emissions 4
dickeymoore Holley vacuum secondary???'s Fuel / Air / Boost / Emissions 2
M Vacuum Question General Discussion 36
yaahoos Vacuum leak causing rough idle? Fuel / Air / Boost / Emissions 3
78_Monte970 Help needed: vacuum lines Transmission / Rear End / Driveline 7
dickeymoore Mechanical secondary or vacuum secondary carb for daily driver Fuel / Air / Boost / Emissions 19
Similar threads
