Depends on how you are going to run. Daily driver needs a lot less fan and cooling area than a street rod. If funds are not an issue, a three row core with a full cover shroud is a good setup. If you run an electric fan, make sure you size the fan diameter and rpm to the maximum heat exchange you will need. A pull through fan is more efficient than a push through. A fan set for "regular" driving will be short of air flow on a street rod and you will run hot every time you step in it. Timing advance can also run the heat up with some setups. I don't have the calculations anymore but I know there is supposed to be a ratio of how much coolant the radiator holds compared to the coolant capacity of the engine. In short, you are much better off with too much cooling than you are without enough. I was taught that the closer you can get to 180 degrees while driving, the better the engine will perform when your foot gets heavy. I'm ancient though and it may be different for the LS.Putting a 5.3 in my 85 Camino. What kind of radiator and fan do I need?
