85 olds 442 paint code
oldsls1
n00b
Jun 15, 2010
4
Hey guys i have an 85 olds 442, 2 tone black and silver/gray. The Car fell off of the jack while i was carelessly pumping, and the fender landed on top of the jackstand.(Damnit!) Ofcourse the fender was smashed. I have no door jam sticker to help with paint codes, I dont know if it makes a difference, but i do still have the sticker inside the trunk. I searched and found a list of paint codes. I was hoping you guys could help me out to make sure i get the proper color. Ill add pictures when i figure out how. Thanks!
http://www.uniquecarsandparts.com.au/co ... sa_A-L.htm
http://www.uniquecarsandparts.com.au/co ... sa_M-Z.htm
oldsls1
n00b
Jun 15, 2010
4
thanks for the help. I did find both paints. I talked to a body shop about repairing the fender, and was told that the lower paint was "gravel guard". He thought this because the entire lower paint job just looks like a bad case of orange peel. Im just wondering if any such product could have been sprayed on from the factory. Giving it this extreme orange peel look?
The paint code for the lower section is wa-8535
Brick442
265
Jersey Shore
my 1985 442 has that "orange peel" gravel guard in the gray--from the factory
usually it doesn't cover the whole gray area, it stops about an inch from the black
82cutty
166
16
My 82 also has the gravel guard from the factory. I used it on my 73 when I painted it to try and keep down the rock chips. You can get it from any paint shop in a spray bomb can either light or heavy. It does not match the factory well at all, they used a spray gun type gravel guard. When I had to replace a fender on the 73 I used the spray bomb style and it was barely noticable. If you find a good painter like I did he can mimic the gravel guard by blowing clear coat in a low pressure. It almost matches 100%, if you didnt know it was fixed you would never know.
