85 ss computer removal-
bowtietillidie85SS
241
Jackson Ms
I have this hunk of wires on my passenger fender that goes into the passenger side of my car to the computer. the only ones that appear in use is a hot wire from battery to starter and 3 ground wires going to my block. anyone know what the grounds would be? other than those 4 nothing else is in use. can i trim out the rest and make them go away until i have the time/space to remove the whole deal?
bowtietillidie85SS
241
Jackson Ms
Re: 85 ss computer removal- Before and after Pics
The day i got the car:
New Carb,plug wires,alt, air cleaner assembly, computer GONE, and just some cleaning up-
Still have a LONG ways to go under there. i believe removing the AC/Heater box is next any tips??
84cutspreme
1,147
152
I've never removed the computer completely but I'd assume a/c & heat is next since they are useless without a computer.
bowtietillidie85SS
241
Jackson Ms
Still have a LONG ways to go under there. i believe removing the AC/Heater box is next any tips??[/quote]
Yep just got to figure out the best angle to attack it at.
Blake442
6,864
1,997
Minneapolis
Both the A/C and heater systems are independant of the cars computer.
Looks like all your A/C is gone, but not only would I not remove the heater, I'd hook the thing back up so it worked.
Blake442
6,864
1,997
Minneapolis
You could keep your heater box intact incase someday you ever decided to put the A/C back in it...
You could also modify it to help reduce clutter and still retain heater function, like this one...
This is 350_85cutty's car...
Or you could go with the factory non A/C set up, but it is a bit more work.
bowtietillidie85SS
241
Jackson Ms
Im not 100% on what im going to do yet. the heater core needs replaced anyway. i may just end up pulling it all and going with a delete plate. im not in any hurry as i have all summer to figure out what im going to do, i would like to find an all stock g body to drive everyday and start modding this one. Lots of ideas... :blam:
